Unknown Vivado USB Port options
I am working on a Zynq UltraScale+ ZU2EG design and I have configured USB0 for 2.0/3.0 operation (Host mode), but there are two options I can not find information on. Can someone please tell me on what "Enable HUB Port" and "Enable V Bus Port" options are for? Please refer to picture below.
Thank you
Re: Unknown Vivado USB Port options
Hi @jawbone_101
Could you please refer below forum post for "Enable V Bus Port" option?
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/What-does-Enable-V-Bus-Port-do-in-Vivado/td-p/792966
Thanks & Regards
Anil B
Thanks & Regards
Anil B
Thank you for the link.It addresses one of the tqo I asked about.
Any additional information about option  "Enable HUB Port" ?
Bump. Any info on "Enable Hub Port"
Hi @jawbone_101 ,
emio_hub_port_overcrnt -> don’t enable this port in PL – let it have the default value ‘0’ . We don’t need this currently.
This is for providing additional Overcurrent fault detection signal to USB controller for disabling it. It can also be passed through ULPI PHY.
Please check this in version 2018.2, the USB2.0 ports "Enable Hub Port" GUI option removed
Thanks & Regards
Anil B
@abommera
Are you saying that option is removed in 2018.2? Below is screenshot from 2018.3 and the option is still there.
Regardless, it seems it is not used for normal operation, so I will not enable this option.
Vivado 2018.3Vivado 2018.3
