athukoralakasun
Using DMA from both ARM Cores
HI,
I am using ZC706 board with SDK2014.1.
I am currently developing a bare metal application for both ARM cores. In that i need to use DMA from both cores. But i coud not figure out how to do this.
I used the example given in "xdmaps_example_w_intr.c"
and impliment that in a single core and it worked fine. But when i used the same code for the other Core as well, It did not work.
Can anyone tel me how to do this??
I have attached the Xilinx example code here.
Thank you.
celeron2000
DMA is just transmitting data between RAM and device via DMA controller (CDMA, AXI_DMA etc). IMHO you can start DMA transaction from every ARM core, using semaphores. First bee shure that all cores have access to FPGA resources.
It's bare metal application, isn't it?
vkosar
It is possible to use single DMA from both CPUs. For the AXI DMA there are two possible solutions:
  1. With interrupts:
    1. CPU0 allocates memory for RX and TX descriptor ring. Those rings should be allocated in noncached memory accesible by both cores.
    2. The RX and TX descriptor ring are initialized by the CPU0.
    3. RX and TX semaphore is initialized by CPU0, those semaphores must be in memory accesible by both cores.
    4. Interrupt handlers are provided by CPU0.
    5. The DMA is initilized by CPU0.
    6. The CPU0 zero informs CPU1 about addresses of descriptor rings and semaphores.
    7. CPUx locks the RX or TX semaphore, set up appropriate descriptors in the ring, updates the tail pointer and releases the semaphore.
    8. If interrupt is being handled by CPU0, the CPU0 locks appropriate semaphore, processes finished descriptors, releases the semaphore. Optionaly it can notify CPUx which initiated the DMA operation that the operation is finished.
  2. Without interrupts:
    4. The DMA is initilized by CPU0.
    5. The CPU0 zero informs CPU1 about addresses of descriptor rings and semaphores.
    6. CPUx locks the RX or TX semaphore, processes finished descriptors, set up appropriate descriptors in the ring, updates the tail pointer and releases the semaphore. Optionaly it can notify CPUx which initiated the DMA operation that the operation is finished.
The RX or TX locks must be held when accesing (write) the RX or TX ring and AXI DMA registers specific for RX or TX direction. Registers which are not specific for direction (eg. reset) must be accessed (written) only when both locks are held.
If the memory buffers are allocated in cacheable regions, then coresponding cache linies must be flushed/invalidated before write/read DMA operation is started.
Note that semaphore locking/unlocking is not a cheap operation and accesing the DMA from both CPUs can be slower  than accesing the DMA from single core.
          VK
Ph.D. student at Brno University of Technology | System Architect at RehiveTech spin-off company
muzaffer
why noncached memory? There is a cache controller with snooping so the processors would get the right data even if it is cached, no?
vgokhale
No. Cache controllers only snoop the processor bus which includes any data going to/from the private and shared caches. They do not snoop the bus to main memory. So if a hardware peripheral were to change the contents of main memory and if the data at that location was cached in one of the L1s, there would be no way for the processors to know that they now have a stale copy. For this reason, any memory accessed by the PL through the AXI DMA should not be cached.
muzaffer
what if the axi master is connected to the ACP of the interconnect?
vgokhale
The ACP will ensure coherency but then you are limited to transfering 512kB of data. Using DMA the "traditional way", i.e. accessing data in system memory will let you access a larger chunk of data.
muzaffer
please clarify how this limitation arises. references to trm would be helpful.
how does ACP not allow one "access data in system memory" ? (other than trashing the cache a little bit :-)
vgokhale
The cache is 512 kB. To acess larger chunks, you'd have to load them from memory and add cache access latency, however small, on top of DDR DMA latency.
My statement does not say this.
If you are going to frequently access data > 512 kB, you'd be better off using AXI DMA over the HP ports.
muzaffer
you said: "ACP ... but you are limited to transfering 512kB of data. Using DMA ... will let you access a larger chunk of data."
as you accept with acp one is NOT limited to 512KB, one can actually access all of the address space the processor or any DMA controller can access. The only potential issue with acp is cache trashing which also can be solved. There is a reason next generation zynq has a fully coherent bus.
