fub
Using UART 1 of Zynq7PS of Zybo Z7
I would like to use the PS's UART 1 of a Zybo Z7 to receive and process messages from the PC via the USB connection on J11 connector.
I am able to send messages from Zybo Z7 to the PC with
xil_printf
Now I would like to use an interrupt based approach to read in and process the messages from PC to Zybo Z7. How do I activate the interrupts for that? How do I implement a corresponding handler in the SDK?
savula
Hi @fub ,
 The ScuGic interrput controller will handle the interrupts in Zynq. If you wnat to use the interrupt on uart then you need to initialize the ScuGic and connect the uart interrupt to it. we have some default example code to demonstrate the interrupt in zynq. please refer this: https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/uartps/examples/xuartps_intr_example.c
Best Regards,
Srikanth
venui
Please follow the example project Uart interrupt in SDK.
Venu
