VDMA problem with Zedboard
    I built a system on zedbeard, it receives video data from an  ethernet camera, and store a video frame in DDR memory. Then I use VDMA to read out the frame data into stream, and the stream will  be displayed on a VGA monitor with the help of v_tc and stream_to_vid_out core.
    by now the data can be received and stored into DDR memory perfectly. and the stream out path seems to be working too. the problem is the video data. I took 2 pictures this morning so you can understand the situation.
    the first picture was taken when every thing in the room is static, you see the system is ok if you ignore the aliasing..
while in the second picture my colleague was moving, and you can see the problem, there are a lot of "delay blocks" in the picture. Generally speaking, these blocks were displaying the pixel data from previous frame or few frames earlier. because my colleague was moving to the left, the blocks on him were displaying white, which is the color of the wall in previous frame, and the position where he was in previous frame, is also kind of black.
Re: VDMA problem with Zedboard
so here is what our system look like
I will attach the mhs as well
    we did some test, as you can see, we connected a chipscope monitor to the HP0 port, so we can see whether the data is correct coming out of ps7.
    first, we write all FFFFFFFF into the frame buffer in DDR, by using XMD, then we checked , the memory used for frame buffer is full of FFs.. note this is somewhere around 0x10003800
    second, we open chipscope to see the bus signals
the bus is in burst mode, so I can only show you 0x10003800 (cursor O) .  the bus will burst 256 byte in the following time.
I put cursor X at the position where the data start to become strange. not FFs as desired any more.
so my colleague and I guess the problem come out maybe because of a wrong way of using the HP0 or ps7.. so far we don't have an idea, have anybody seen this situation before?
fan
Hi, I have met the simple problem with the Video DMA on Zedboard. When using VDMA  to ransfer an image(32bit per pixel), small image such as 1024*250*32 is OK,  but a larger one such as 1024*1024*32 always comes with packet loss. I think the problem may be the vdma fifo setting.
My project:project.png
My Result Compare:
  thanks for reply
  So you still have that problem now? or you soved by some other way.
fan
Hello,have your problem  fixed or not? I'm very interested in you design,and i want to do like your project ,but i don't know how to start,do you have some tips to me.
Did you try to increase the values for Linebuffer Depth/Threshold or even the burst length?
In one of their sample designs Xilinx is using a depth=8192 and threshold=8160 for hd-frames.
I'm not familiar with the Zedboard, I'm using the ML605 board, with Vitex 6 family FPGA. My design used four (04) HD 1280x720P60 or 1920x1080I30 cameras as inputs via triple SDI, GTX Transceivers at the rate of 1.5 Gbs and CONCURRENTLY DMAing in and out an External DDR3 DDRAM using the  4 pairs of VMDA, AXI4, AXI lite, MIG all being controlled by MicroBlaze processor.
I believed my design throughput is much higher than yours, I have no problem at all (remember I display on an HD Monitor not VGA Monitor).
While configure VDMA IP, I only set the line buffer is 2048 since my scanline is 1280 or 1920 pixels of 20-bit YCrCR, 11-bit line number. burst size is set to maximum 32, Input or Output FIFO depths set to 512.
I don't believe your problem related to the AXI-VDMA bandwidth, look for issue in other part(s) of design.
Good luck
ktn
I'm newbie with Zedboard. I'm wondering, where are getting the pictuures. There are no camera on the picture of the system.
om_pimi
The problem seems to be in the read and  write of  data from FIFO , Please can you try increasing the read write clock of the FIFO.
When you are trying to push the data out the pixels are not formed properly and unable to form a picture clearly while displaying this is completely a throughput problem.
hello,   I  am  a  student  who   is  designing  a  project  which  is  similar  to yours.  Now, I have  achieved    some   tasks,and    I   can   get  images  through    ov7670   and   VGA   on  the   ZedBoard  of  Xilinx . And ,I  have  configurated    the  ov7670  in  PL part  of   Xilinx   ZedBoard .  however,  the   images  is  stored  in the SRAM  IP .   I   don't  know how  to    use VDMA to connect the 0v7670 Camera  and   DDR3  .    Also ,  I   do  not  know  how  to    package   my  "ov7679  capture  ip "    to    AXI Stream .   And  ,how  to  use  the  Video In/out to AXI Stream  ?   Please ,  can   you  share   your   project  with   me .   This is my mailbox , liangxinyu86@hotmail.com !
hello, i am a biomedical engineer who is currently working with the ov7670 in a project accelerating computer vision algorithms. I have downloaded the project from hamsterworks. However, i am not getting a good image. I am having trouble with the colors. If it is possible, can you share me the code to make it work. I am sending you a picture with the colors i am getting. Thanks...
Hello everyone!
Also have troubles while connecting OV7670 to DDR3 on Zybo. I'm trying to make a ring buffer using VDMA like in this article:
https://lauri.xn--vsandi-pxa.com/hdl/zynq/xilinx-vdma.html
But it still doesn't work for me.
Is there anyone who has successfully made a similar design?
