VFBC interface to my custom IP
Hi there :-)
I am using a Spartan 3A DSP board ( xc3sd3400a-4fg676 ) for image processing applications along with the Video Starter Kit.
I want to access the image stored in the external memory through VFBC connected to my MPMC.
I wrote a basic verilog code consisting the interface signals for VFBC initiator.
I wrote the MPD and PAO file and exported it as a pcore to my EDK project.
However I am not able to generate the bitstream for the design.
The error says MDT-Platgen failed with errors.
Could you please help me solve the error?
Thanks a lot.
joshual
The flow you did is correct, but we need the detailed error information to help you identify the problem
Hi Joshualu :-)
Thank you for the reply,
I was able to solve the problem. The model is synthesizing. There was a small mismatch between my MPD and verilog files so it was not synthesizing. Now it s solved.
Thank you,
Have a nice day :-)
