aminfar1
Vector processing using Microblaze
I am going to add a coprocessor to Microblaze using FSL to add some vector processing. The coprocessor gets a stream of data, does some operations, and returns a stream of results. I have seen some articles that say vector processing works in Microblaze. However, before writing any HDL code, I would like to know the caveats and pitfalls of vector processing using a coprocessor on Microblaze processor. For example, what should I and what should not I expect from vector processing using a coprocessor?
Since performance is really important in my application, I don't want to end up having a slow coprocessor. So, if any one has any experience on that issue that might enlighten me, I would be grateful to know.
Message Edited by aminfar1 on 09-30-2009 04:04 PM
martinthompson
One thought for you:
Your data has to pass through the microblaze - therefore, you have to use (at least) one clock cycle to write each vector value and one to read each return value (if it's just a vector summation, then there might only be one of those).
If you can make your "vector " accelerator interface directly to the data source, then you will improve matters, so that the microblaze doesn;t spend its whole time pushing data to and from FSL ports.
Cheers,
Martin
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
aminfar1
Martin,
Thanks for your good point. Can you elaborate it?  How can I make the "vector " accelerator interface directly to the data source? Do you mean by means something like DMA?
Amin Far
martinthompson
Ideally, the accelerator would get it's input data direct from the source, without going through the memory hierachy.  This is not always possible, in which case a DMA might be appropriate.
Can you tell more of the specifics of your application?
Cheers,
Martin
Martin Thompson
aminfar1
Martin,
Ok, I need to do a lot of matrix multiplications that matrices are usually large and are composed of either float (32 bits) or double (64 bits) or even 54-bit values. I wanted to have a coprocessor that gets array elements from the processor and returns the results. So, it gets arrays elements of A and B, and return C, C = A * B.
since I don't want to use the FPU of Xilinx (because I might have, for example, 54-bit values. So FPU cannot do anything for me), I wanted to design a custom matrix multiplier coprocessor that is capable of doing fast multiplication of matrices (there are plenty parallelism that I can take advantage of).
I hope this helps explain my problem. Thank you for you contribution and looking forward to hearing from you.
martinthompson
Funnily enough, I have just such a matrix multiply core (currently single precision, but it could be tweaked), for a standalone system that I am working on.  I'm sure it could be integrated into XPS with a bit of effort.
Contact me off list if you are interested...
Cheers,
Martin
Martin Thompson
