Fajung
Versal mater SPI how to conncet 100 pcs SPI slave devices
Hi Sir:
If we have about 100 pcs SPI slave devices need to control from Versal.
I see the Versal datasheet CS_N can use external 3 to 8 decoder to extend , but look like still not enough….
Do you have any suggestion about SPI block diagram design?
BR.
Tags (3)
venui
Hi @Fajung ,
You can find the information related to SPI controller in the Versal TRM https://www.xilinx.com/support/documentation/architecture-manuals/am011-versal-acap-trm.pdf chapter 70
We have provision to access up to 8 slave devices only using PS SPI controller with 3 to 8 decoder logic.
Venu
venui
Hi @Fajung ,
Venu
Fajung
Hi Venu:
Versal have two SPI controller (SPI0, SPI1), so each controller can use 3 to 8 decoder logic, is correct?
BR.
venui
Hi @Fajung ,
Yes you are correct.
Venu
