Anonymous
Not applicable
Vivado 2014.3 生成的Boot.bin不能启动
我有一个ZYNQ 7020的设计以前是在ISE14.5上做的,生成的BOOT.bin能正常运行。但是我把设计移到Vi​vado 2014.3上后(流程按照手册正常操作的),生成的BOOT.bin不能启动。我将SDK的fsbl​_debug.h文件中的FSBL_DEBUG_INFO 定义后,串口的打印输出入下:(SD卡启动)
Xilinx First Stage Boot Loader
Release 2014.3  Oct 28 2014-10:39:59
Devcfg driver initialized
Silicon Version 3.1
Boot mode is SD
SD: rc= 0
SD: Unable to open file BOOT.BIN: 1
                                   SD_INIT_FAIL
FSBL Status = 0xA009
This Boot Mode Doesn't Support Fallback
In FsblHookFallback function
期待您的答案!Thanks!
norman_wong
I've met with the same problem. Are you using an older SD card? I found that my old 1GB failed and my slightly newer 4GB card succeeds.
norman_wong
Anonymous
Not applicable
Yes ! The problem got solved.
Thanks for your help!
