WARNING: CONFIG.PSU__PSS_REF_CLK__FREQMHZ not found. Using default value for XPAR_PSU_PSS_REF_CLK_FREQ_HZ.
  I've met said warning message.
  It turns out there is a bug in
     https://github.com/Xilinx/embeddedsw/blob/f975a0ea90930587ab55e4d920a31950bd373fa8/lib/bsp/standalone/data/standalone.tcl
  function
proc get_psu_config {name} {
    set ps_periph [hsi::get_cells -hier zynq_ultra_ps_e_0]
  where the "instance name" "zynq_ultrascale_ps_0_e" is hardwired.
  I did use a different instance name in my design and thus this "proc" failed.
  I suggest to replace this with something similiar to
hsi::get_cells -filter { IP_NAME == "zynq_ultra_ps_e" }
Hi @larice,
Thanks for reporting that.
I have created a change request to our development team in order to fix that.
Abdallah
Hi @larice,
Abdallah
Thank You,
Best Regards,
Robert
namespace eval _tcl {
proc get_script_folder {} {
   set script_path [file normalize [info script]]
   set script_folder [file dirname $script_path]
   return $script_folder
variable script_folder
set script_folder [_tcl::get_script_folder]
# Check if script is running in correct Vivado version.
set scripts_vivado_version 2018.3
set current_vivado_version [version -short]
if { [string first $scripts_vivado_version $current_vivado_version] == -1 } {
   puts ""
   common::send_msg_id "BD_TCL-1002" "WARNING" "This script was generated using Vivado <$scripts_vivado_version> without IP versions in the create_bd_cell commands, but is now being run in <$current_vivado_version> of Vivado. There may have been major IP version changes between Vivado <$scripts_vivado_version> and <$current_vivado_version>, which could impact the parameter settings of the IPs."
