Watchdog: freeze when reading clock control register on MPSoC
I'm trying to use the system watchdog on Zynq UltraScale+ MPSoC. I have configured SWDT1 in IP integrator and generated the FSBL with SDK.
When testing, the FSBL freezes during boot. I have traced the cause back to the following statement in xsdtps.c, which reads the clock control register:
 XWdtPs_ReadReg(InstancePtr->Config.BaseAddress,
				 XWDTPS_CCR_OFFSET);
Removing the watchdog initialization form the FSBL, booting Linux and writing to /dev/watchdog0 also causes a system freeze.
Am I missing some initialization or configuration?
Thanks!
It seems like this problem is fixed after applying the patch from AR# 69423:
https://www.xilinx.com/support/answers/69423.html
