11-16-2013 11:46 AM
I am migrating working ZYNQ Z7020 design for our HW product from PlanAhead 14.6 to Vivado 2013.3.
So far so good. I get better results from Vivado (in terms of resource utilization) than in PlanAhead for the same functionality (looks like what they say is true :-)).
What bothers me is S_AXI_HP0_FIFO_CTRL (and HP1, HP2) interface which are enabled as soon as I enable HP AXI port in ZYNQ7 Processing System “Customize Block” configuration.
I did not find any enable/disable option regarding this HP AXI FIFO control interface and also no description/documentation what it is.
In PlanAhead XPS 14.6 there was nothing about it, so I left it unconnected.
Building this design in Vivado 2013.3 produces no Errors/Warning regarding it and also design works OK. It looks like this is some kind of “debug” interface.
I searched on WEB (Xilinx and Google), UG585 (TRM) and PG082 (PS7 v5.3). I did not find any reference to this HP AXI FIFO control interface.
Anybody knows where this S_AXI_HP0_FIFO_CTRL interface is described?
11-16-2013 08:32 PM
Looking at the MPD file the FIFO_CTRL interface is enabled when we have C_USE_S_AXI_HP being set.
IO_INTERFACE IO_IF = S_AXI_HP0_FIFO_CTRL, IO_TYPE = XIL_HP_FIFO_CTRL_V1, ISVALID = (C_USE_S_AXI_HP0 == 1)
Looking at table 2-6 of the TRM, it looks S_AXI_HP is called AFI. Table 5-5 of TRM talks about AXI_HP register overview.
--HS
11-16-2013 08:32 PM
--HS
11-17-2013 01:47 AM
Thanks for the hints.
What I was looking for is described in TRM chapter 5.3.6 Bandwidth Management Features, Table 5-6. Names in TRM for this isgnals are a little bit different from names used in Vivado IP Integrator (eg SAXIHP0... vs S_AXI_HP0_...).
The header of TRM Table 5-6, could be extended to look like Table 5-8, making search in TRM easier.
Will mark as solved.
