What is the difference between the interrupt and the break in MicroBlaze?
HI:
    What is the difference between the interrupt and the break in MicroBlaze? when is the interrupt used,and when is the break used?
    Thanks!
goran
Interrupt input are normally tied to the interrupt controller and are used for peripherals.
Breaks (Ext_BRK and Ext_NM_BRK) inputs are normally only used by the MDM module for trying to get control over MicroBlaze.
There is a chapter in MicroBlaze Reference Guide called "Reset, Interrupts, Exceptions and Break" which goes into more details on this.
Göran
HI,
HI,
HI,
    I see. Thanks very much!
