bang0306
What's the difference between generic interrupt controller and xilinx interrupt controller?
When I read the code in xaxicdma_example_simple_intr.c, I saw two interrupt controllers, generic interrupt controller and xilinx interrupt controller, whose drivers defined in xscugic.h and xintc.h.
What is the difference? When should I use one over the other?
This is a piece of code from xaxicdma_example_simple_intr.c
#ifdef XPAR_INTC_0_DEVICE_ID
#define DMA_CTRL_DEVICE_ID	XPAR_AXICDMA_0_DEVICE_ID
#define INTC_DEVICE_ID		XPAR_INTC_0_DEVICE_ID
#define DMA_CTRL_IRPT_INTR	XPAR_INTC_0_AXICDMA_0_VEC_ID
#else
#define INTC_DEVICE_ID		XPAR_SCUGIC_SINGLE_DEVICE_ID
#define DMA_CTRL_IRPT_INTR	XPAR_FABRIC_AXICDMA_0_VEC_ID
#endif
what does XPAR_INTC_0_DEVICE_ID mean? When will it be defined?
tayres
I had this exact question!
Looking at the modification history of xuartps_intr_example.c I think it might have something to do with the Zynq Ultrascale+ MP:
* 3.1	kvn		04/10/15 Added code to support Zynq Ultrascale+ MP.
* 3.1   mus     01/14/16 Added support for intc interrupt controller
muzaffer
@bang0306 Xilinx interrupt controller is the PL based interrupt controller IP Xilinx made. Generic interrupt controller is the one built into the ARM SoC side.
