Voyager
Voyager
When do I need " Xil_ICacheEnable(); Xil_DCacheEnable();"?
I found some Xilinx software design, in main function, there are two functions called at beginning:
Xil_ICacheEnable();
Xil_DCacheEnable();
These two are just macro which are :
microblaze_enable_dcache()
microblaze_enable_icache()
seperately. So based on the name, they are used to enable the microblaze cache. My question is when I need them? If I don't call them, the cache inside microblaze will not work?
Thanks in advacne.
Re: When do I need " Xil_ICacheEnable(); Xil_DCacheEnable();"?
These functions are needed to enable them on the software side. You have to enable cacahe functionality in both hardware and software side.
Check this thread. This has some more details that will be helpful.
http://forums.xilinx.com/t5/Embedded-Development-Tools/XPS-Microblaze-cache-enable-and-execution-time/td-p/39112
Sikta
Sikta
Voyager
Voyager
Hi Sikta,
Thank you very much for posting the link. I try to enable the cache in Microblaze, after configuration, I can see the microblaze has two new ports : AXI_DC and AXI_IC, so I should connect these two ports to ram? I think I need manually create RAM instance in bd, right?
Do your design use external memory like DDR ?
If the accessible memory is BRAM only then I don't think that the cache will improve design performance.
Praveen
First of all if you have a DDR in your system, it is recommended to have caches in microblaze. When MicroBlaze starts, the data cache is disabled. The data cache must be enabled explicitly with the functions above.
I believe the functions microblaze_enable_dcache()
microblaze_enable_icache() are old.
Check Os Libraries and Collection document for more details:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/oslib_rm.pdf
Voyager
Voyager
Thank you, all of you.
