Where can I find more information about the 'completed' bit from the axi dma?
In this manual: LogiCORE IP AXI DMA v7.12PG021 June 14, 2019
I found this section:
Where can I found this 'completed' bit? Is it referring to ioc?
Or does it refer to: DMA_COMPLETE => https://github.com/Xilinx/linux-xlnx/blob/master/drivers/dma/xilinx/xilinx_dma.c#L1241
Hi @verlindenjan:
Short Answer:
It refers to the "Cmplt" bit of the STATUS field on each descriptor (MM2S_STATUS[Cmplt] or S2MM_STATUS[Cmplt]).
Long Answer:
On Scatter Gather mode, each descriptor within your descriptor chain will be fetched, processed, then updated (check Descriptor Management section from PG021).
On the update step, the DMA updates the STATUS field for each descriptor. One of the bits that will be updated is the "cmplt" bit, to mark that this descriptor has been processed.
Abdallah
Hi @verlindenjan:
Short Answer:
Long Answer:
Abdallah
