tflekan_ddc
Where can I find the Zynq UltraScale+ MPSoC Verification IP for Vivado 2020.2?
Where can I find the Zynq UltraScale+ MPSoC Verification IP for Vivado 2020.2?  It isn't in the normal IP library.
Tags (2)
florentw
HI @tflekan_ddc
This is added when you add the Zynq MPSoC IP. This is the simulation model of this.
Florent
florentw
HI @tflekan_ddc
Florent
tflekan_ddc
I understand now.  The Verification IP and the associated tasks are built in to the MPSoC IP and it's unnecessary to load additional IP.  Thank you for spelling this out so clearly.
