deepak1991
Whether it is possible to program a FPGA(zynq fpga) using ARM PL JTAG,if possible then which cable i have to use and how to program?
Hello everyone,
             I am using Zynq ZC702 evaluation board.whether it is possible to program a bit file using ARM PL JTAG,If it is possible then please let me know how to do that.And which cable i have to use for programming the FPGA?
florentw
Hi @deepak1991,
Yes this is possible to program the PL using the JTAG:
-> use the platform cable if you have one
-> use a USB to micro USB cable to connect with the USB JTAG interface using a Digilent module
Remember to select the JTAG configuration for the SW16.
Hope that helps,
Florent
Florent
