joe306
Which printf or xil_print?
Hello, quick question relating to printing to the counsel during debugging. Is there any difference between xil_print and printf? Does one use more resources than the other?
Thank you
Tags (2)
savula
Hi @joe306 ,
Both are same. you can use any one of them.
Best Regards,
Srikanth
savula
Hi @joe306 ,
Best Regards,
Srikanth
maps-mpls
Mentor
Mentor
@savula are you sure?  At one time they were not the same.  I thought one was lightweight (i.e., didn't support %f), the other was not (e.g., supported %f).  I don't have time to check right now.
*** Destination: Rapid design and development cycles *** Please remember to give internet points to those who help you here. ***
dpaul24
@savula ,
If both are same why was xil_print created after all (from a developer's point of view it does not make much sense)?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
barriet
I'm not the expert here, but definitely also remember them NOT being the same.
A quick check of the current OS libraries reveals
xil_printf
xil_printf() is a light-weight implementation of printf. It is much smaller in size (only 1 Kb). It
does not have support for floating point numbers. xil_printf() also does not support
printing of long (such as 64-bit) numbers.
from https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/oslib_rm.pdf page 10.
Cheers,
bt
joe306
Thank you very much
