Anonymous
Not applicable
Why can't disable interrupt of microblaze?
I am using interrupt of microblze to capture an external interrupt with out interrupt controller, my c language codes are as below.
When an interrupt come, a * is printed.
after 10 *, it is expected that interrupt be disabled and nothing printed.
But things is different, it seemed that interrupt can't be disabled
(EDK 10.1.3)
#include "xparameters.h"
#include "stdio.h"
int i=0;int
XInterruptHandler my_handler(void)
 if(i==10) {print("=");}
 else{print("*");i++; }
 //return 0;
int main (void)
 XStatus status;
 void * DataPtr;
 microblaze_register_handler(my_handler,&DataPtr);
 microblaze_enable_interrupts();
 while(1)
    if(i==10)
        microblaze_disable_interrupts();
return 0;
Anonymous
Not applicable
Re: Why can't disable interrupt of microblaze?
Yes! powerful volatile.
Your global variable should be declared as 'volatile'
-Brian
Anonymous
Not applicable
