Working With LVDS interface on Artix 7 FPGA
Hi Guys,
I am Using Artix 7 fpga. I need to implement a LVDS interface on FPGA. I have a ADC data output as 16 channel LVDS which need to given to FPGA for Further Processing.
How do i go about the to solve the above problem.
Please suggest me possible ways to make it work.
Thanks and Regards
Suraj
gaonkar@123- Below application notes combine are having some useful information with respect to your application requirement. Please check
https://www.xilinx.com/support/documentation/application_notes/xapp594-parallel-lvds-hs-dac-interface.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp585-lvds-source-synch-serdes-clock-multiplication.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp524-serial-lvds-adc-interface.pdf
