Write to multiple AXI4 stream simultaneously
Hi everyone,
I'm working on a design with 2 AXIS input ports and 1 AXIS output port on Zynq7000.
Both input ports will read data from memory simultaneously.
I've done 1 AXIS input and 1 output before, with a DMA, a AXI SmartConnect and a AXI_HP port on Zynq.
1. How do I connect Zynq to this IP? 2 DMA, 2 AXI SmartConnect and 2 HP ports?
2. How do I program the cpu so that it will initiate data transfer to both ports? Use multithreading?
