Writing Zynq board custom XML configuration file for Zynq-7015
I am looking for some sort of documentation on writing an XML configuration file for describing Zynq PS. Does such a document exist?
A few sources say just use Xilinx Platform Studio (XPS) and export the xml file but (I have done this and) there are problems with using XPS:
1) Does not support certain Zynq chips/packages (e.g. I'm using Zynq-7015 which is not supported on XPS)
2) Certain configurations that can be configured using the PS Configuration Wizard (PCW) in Vivado are not possible to configure in XPS; e.g. enabling/disabling multiple FCLKx PL clock outputs and enabling F2P_IRQ[15:0] interrupt vector
Those are the main problems I am having now and there is very little (if no) documentation on the interwebs about writing PS xml configuration files and the possible PCW parameters that can be configured and their names, etc.
Any help is appreciated. Thanks.
WRONG WROMG WRONG
this is supported in Vivado 2014.4 and newer, you can save and load PS config now. This is  new in 2014.4
PLEASE stop using ISE/XPS they do not exist :)
Community Manager
Community Manager
As trenzal pointed out, please use Vivado to create the bitstream of your design and exporting the design will generate hdf/xml files.
