jcgcecilia
Writing to memory with Microblaze
Hi!
I am working on a project in which I want to save a large amount of data into DDR-Ram with Microblaze.
My code is the following:
Xuint32 Index = 0;
while (Index < 500)
  *Buffer = pic[Index];
  xil_printf("\rAddress = %x\t Value = %d\n",Buffer,*Buffer);
  Buffer++;
--It is very simple, I have an array of data (pic) which I want to store in memory. I am using an integer pointer to memory. I write to memory and increment the pointer.
The code listed previously should save 500 item from my array in memory. I have 64MB, so space is not an issue.
The problem is that I can not do that.
Looking at the terminal this is what is shown:
Address = 44000180       Value = 16777215
Address = 44000184       Value = 16777215
Address = 44000188       Value = 16777215
Address = 4400018C       Value = 16777215
Address = 44000190       Value = -1240530936
Address = 44000194       Value = 539033620
Address = 44000198       Value = 807534548
Address = 4400019C       Value = -102694912
Address = 440001A0       Value = -94306264
Address = 440001A4       Value = 308346880
Green = Rigth
Red= Wrong
Max data saved into memory correctly = 396
Anyone can help me with that?
Best regrads
Juan carlos
maxman
Try this
Xuint32 Index = 0;
while (Index < 500)
  Buffer++;
  index++;
max
