XADC Wizard v3.0 Stream usage?
Does anyone know how to use AXI4-Stream for XADC?
i have enabled this function, but the tdata is always the same value, and tvalid always high.
(using ila to monitor bus signal)
ps.the Temp data read from PL-AXI is correct
has anyone tried this function before?
Owen
Owen,
Did you ever have any luck in getting this setup?
Thanks!
