rmugridge
XAdcPs_SelfTest in FSBL fails on soft reboot
I've enabled the XAdcPs in my FSBL in order to read a value at startup.  On power up, the value reads ok.  However, on a soft reboot from linux, the XAdcPs_SelfTest function fails - the readback of the test value is 0x00 rather than 0x55.
As far as I can tell, the XAdc is not enabled in my linux build.  I've tried with and without the PL being programmed at the point of reboot.
This is on a ZC702.  The code sequence in the FSBL is...
XAdcPs_LookupConfig
XAdcPs_CfgInitialize
XAdcPs_SelfTest
Can anyone suggest what might be causing the failure on reboot?
Robin
rmugridge
Update: This is a failure on ES devices.  Later silicon revisions are fine.
rmugridge
