XCZU3EG-SFVA625I DDR4 CK to DQS Timing
*This is a repeated post from the Memory Interface forum due to no responses*
I just finished the initial layout for the XCZU3EG DDR4 interface using fly-by routing topology and two Micron MT40A512M16JY-083E IT:B DDR4 SDRAM 8G-Bit 512Mx16. My question is about the skew constraint between CK and the DQS signals. The example in UG583 is straight forward but I was looking for a little more information on devices that have two byte lanes per chip and a single CK input. My initial flight times from the Zynq to the DDR are listed below:
DDR1 -> CK = 93ps, DQS0 = 201ps, DQS1 = 194ps
DDR2 -> CK = 182ps, DQS2 = 280ps, DQS3 = 255ps
I have not delay matched the traces yet. Is it ok that my byte lanes arrive out of order (DQS1<DQS0<DQS3<DQS2) or do I need to lengthen my traces so that they arrive sequentially? Seems sequentially would be the logical choice but the DQS/DQ signals don't have any constraints across byte lanes so it leads me to believe the error handling can correct for that. Byte lane swapping is also allowed so that makes me feel like the write leveling can correct for the out of order arrival times.
If they can be left out of sequential order, does the CK constraint for the "first device" apply to the fastest DQS or to DQS0 always?
Thanks in advance,
Kyle
Re: XCZU3EG-SFVA625I DDR4 CK to DQS Timing
Is there any other way to get technical support from Xilinx on the usage of their processors since the forums don't appear to be very active?
