XLAT Axi stream to Memory map
Good morning
I need the simplest basic way of translating the flow through the AXI stream in the memory mapped.
I do not want to have any DMA or fifo on the scene. I need the source code of a simple translation.
Is there a suggestion where do I find such code?
Thank You
Pietro
Tags (3)
Hi @pietro_dcs,
You are welcome.
No, not AFAIK.
Best regards,
Abdallah
Hi @pietro_dcs,
Does AXI_Streaming_FIFO fulfil your need?
If no, please try to elaborate.
Best regards,
Abdallah
Good morning
Thank You for the suggestion.
It is the most similar component for my need. For now I will use.
I would like to have a simpler solution in my hand to customise as needed.
If You have a source accessible solution let me know
Thank You
Pietro
Hi @pietro_dcs,
You are welcome.
No, not AFAIK.
Best regards,
Abdallah
