Anonymous
Not applicable
XMD remote
We have our xilinx tools running on a central server, but the xilinx board local on the lab workplace.
Until know we configured the FPGAs with the cableserver and impact via a normal network connection. This is no problem having a normal webpack on the local computer with the cableserver.
Is it also possible to use the XMD (the license is only available on the central server) and connect to the cable server in order to debug the system from remote?
Thanks for your help.
Sebastian
Re: XMD remote
I believe that XMD is tied into the EDK tools, so if you are asking if you can use XMD in a standalone fashion, then the answer can be found here - http://www.xilinx.com/support/answers/22138.htm
Anonymous
Not applicable
Re: XMD remote
No. I don't want to use it in a standalone fashion.
As it is already possible to use the 'Cableserver.exe' ,that comes with the standard Webpack, to remotely configure the FPGA from anywhere in the world, as long as the local user has the Webpack.  My question is: can I also remotely debug the FPGA with the same interface using XMD instead of Impact to connect to the Cableserver.
