09-04-2018 01:32 AM - edited 09-04-2018 01:37 AM
This question is very related to the AR#71015. I generated an isolated system following the guidelines explained in:
and I concluded with this setup:
APU no secure:
APU secure:
PMU:
RPU:
On that system I could:
But I couldn't run standalone apps on the R5 processors when booting from the SD running the FSBL on the A53 processors. For this reason, I added the CRL_APB (secure) module to the RPU as explained on the AR#71015. But that solution is not working. Could you check my setup?
I don't know how to do this:
"... or modify the code to route CRL_APB access to the PMUFW using xilpm" (which is the other solution explained on the AR#71015)
If I bypass the isolation configuration in the FSBL, it works.
My final goal is to run Linux from the high memory on the APU and standalone/RTOS apps from the low memory on the RPU while sharing some part of the memory. I could do that using v2017.3 of the Vivado tools when the isolation was not enabled.
09-04-2018 05:23 AM
I found the solution:
I had to add the RPU node to the APU-secure subsystem. It is necessary because the FSBL put the R5 cores in Lovec/Hivec in the function XFsbl_UpdateResetVector.
Now I can launch standalone apps on the R5 processors from the SD with isolation enabled.
09-04-2018 05:23 AM
06-21-2019 06:49 AM
I noticed you referenced xapp1320. I just released a major update to that document (revision 2.0). Additionally, Vivado release 2019.1 has a default "secure system" that address some of these concerns as] well.
