XPS_TFT: Video Memory Adress
The problem come when I try to ouput two images: an original image with noise and its filtered image. I can control the VGA without problem but I do not understand how the video memory configuration works. I would like to  This is an example code that shows what I am trying to do:
  // Mapped Memory: 0x0 -0x03FFFFFF 64MB DDR
  // 2MB (0x001F0000) is needed for the xps_tft controller to storage the 640x480 image
   // write the original image    ( 0X02000000 is the BASE ADDRESS MEMORY for the video memory. This is defined in xps)
  sleep(100);        // wait to see the original image
  XTft_SetFrameBaseAddr(&TftInstance,0x03000000);    // change the base address for the video memory to write the filtered image
 // write the filtered image .
 sleep(100);        // wait to see the filtered image
XTft_SetFrameBaseAddr(&TftInstance,0x03000000);     // return to the original image
I can see the original image perfectly but the filtered appears incorrectly. I do not think it is a problem with the memory range cos :
(BASE_ADDRESS    +  2MB)
original image range:                     0x0200 0000      -     0x021FFFFFF
filtered image range:                      0x0300 0000      -     0X031FFFFF
Does anyone know what I am doing wrongly?
Thanks in advance
Re: XPS_TFT: Video Memory Addres
I have found out where the problem was. Everytime the base address video frame is changed, it is very important to clean the screen to initialize that new memory.
Bye.
Bye.
