XPS_TFT on Spartan-3a DSP 3400a
I'm doing my first steps with FPGAs and the Xilinx Tools and the LCD is already running :)
But now I'm trying to get the xps_tft IP running on my Spartan-3a devboard using EDK 11.2 but nothing happens on the tft.
Before I post a lot of code, please, can anyone tell me how do I figure out how I have to configure the pins (IOSTANDARD etc) in the system.ucf?
I attached some parts out of my system.ucf/.mhs, maybe anyone find the failure(s).
Thanks a lot,
Alex!
Re: XPS_TFT on Spartan-3a DSP 3400a
Has anyone already managed to get this working? I have found the pin configurations in the documentation and the reference documents, but the monitor does not receive sync signals.
The reference designs use other custom IP, but I would like to use the standard IP library only.
My guess is that some software initialization is missing (I2C programming).
Any help would be greatly appreciated.
Tommy Kamps
I didn't continue trying to get the xps_tft working. Have you tried the sw examples in this thread?
The XPS TFT attempts to configure the Chrontel DVI chip (using IIC) itself.  I believe the 3400 board has an IIC mux on this bus, and I don't know that the Chrontel is selected by default.  I think you will probably need to use an xps_iic core in your system, and configure the mux and Chrontel with your own software.
-Brian
