XPS_Timer
Hello!
  Could someone tell me what units are used when sampling an xps timer in a disign using the following code snippet?
 // Xuint32 Variables
   XTmrCtr xps_timer_0;
    XTmrCtr* timer_0 = &xps_timer_0;
    XStatus Status;
   Xuint32 BeginTime;
    Xuint32 EndTime;
    Xuint32 Calibration;
    Xuint32 TimeRun;
  BeginTime = XTmrCtr_GetValue(timer_0, XPAR_XPS_TIMER_0_DEVICE_ID);
     EndTime = XTmrCtr_GetValue(timer_0, XPAR_XPS_TIMER_0_DEVICE_ID);
     Calibration = EndTime - BeginTime;
 BeginTime = XTmrCtr_GetValue(&xps_timer_0, XPAR_XPS_TIMER_0_DEVICE_ID);
    SOME_FUNCTION_CALL(parameters);
 EndTime = XTmrCtr_GetValue(&xps_timer_0, XPAR_XPS_TIMER_0_DEVICE_ID);
TimeRun = (EndTime - BeginTime - Calibration);
xil_printf("Time to run SOME_FUNCTION_CALL: %d\r\n", TimeRun);
Crono
Re: XPS_Timer
Crono,
Yes.
-Brian
Re: XPS_Timer
The units are whatever the frequency of the clock that's fed to the xps timer periperial.  If, for example, this is 100MHz, then each integer value in the count is 10ns.
-Brian
Re: XPS_Timer
So, what you are saying is: every integer value represents one clock cycle?
-crono
Re: XPS_Timer
Crono,
Yes.
-Brian
