sha@hys
XPS error when configuring microblaze
I am working in spartan 6 XC6SLX45. I want to configure microblaze in it and is using xilinx XPS for same. But I am getting following error and duont know to solve it . Kindly make some suggestions.
EDK:3900 - issued from TCL procedure "check_error" line 12
C_MASK (IPNAME:lmb_bram_if_cntlr, INSTANCE:microblaze_0_i_bram_ctrl) - Can
not generate mask for the LMB peripherals! An address decode mask is assigned
to all LMB peripherals connected to the MicroBlaze processor. The address
decode mask is based on a set of decode bits that distinguish the LMB address
space from the OPB/PLB/AXI address space. The error message indicates that a
set of decode bits can not be found to generate a mask. Please modify the
address map of the slaves connected to OPB/PLB/AXI to use a common address
bit.
ERROR:EDK:4114 - IPNAME: lmb_bram_if_cntlr, INSTANCE: microblaze_0_i_bram_ctrl -
error computing override value for C_MASK using tcl -
C:\Xilinx\14.7\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\lmb_bram_if_cntlr_v3
_10_c\data\lmb_bram_if_cntlr_v2_1_0.mpd line 92
ERROR:EDK:3900 - issued from TCL procedure "check_error" line 12
C_MASK (IPNAME:lmb_bram_if_cntlr, INSTANCE:microblaze_0_d_bram_ctrl) - Can
bit.
ERROR:EDK:4114 - IPNAME: lmb_bram_if_cntlr, INSTANCE: microblaze_0_d_bram_ctrl -
ERROR:EDK:3371 - Conversion to XML failed.
my address tab is also shown
Thanks in advance.
Tags (2)
sha@hys
I have changed value of c_mask of lmb controllers.
venkata
Please check if the thread below is relevant to you
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=EDK&message.id=28594
htsvn
hi,
can you assign an address to the bridge of axi_plb and the spi controller manually?
it looks that all of these are overlapping with lmb bram controller
--hs
sha@hys
