Xil_DCache_Flush() and Xil_DCache_FlushRange
i tried both, maybe i have some bug in my design but
 Xil_DCache_FlushRange works but is slow,
Xil_DCache_Flush() doesn't flush correctly, looking at the assembler it seems that it doesn't calculate correctly the cache limits.
I enabled write back cache, cache victim, line lenght 4, 32kB data cache
This is a known issue. This will most probably fixed in 2014.1 version of the tool.
Thank you for your reply
you mean the Xil_DCache_Flush() not working right?
or  Xil_DCache_FlushRange() slow problem?
by the way, it seems to me that the AWLEN signals from Microblaze are tied to GND...
can i use burst with Microblaze??
