Xil_Out16 abort handler
Hello
I am trying to read and write to AXI EPC from PS. I am using Xil_Out16(Addr, Value). Its always struct at abort handler.
Can u please tell me what is the problem
I am using vivado 2016.1
And same example if I try in vivado 2015.4 its working.
Thanks and Regards
Sri
Re: Xil_Out16 abort handler
Hi @sridevi123,
If the above idea from @ritakur has resolved your issue please mark his post as accepted solution to close the post.
Praveen
If you get a data abort exception when accessing to an address.
Normally this address range is not defined in the MMU table.
Also AXI EPC is in the PL, please also check if the PL is configured.
Thank you for the reply
That problem got solved. EPC waits for Ready signal.
Sri
Hi @sridevi123,
Praveen
