Xilinx Zynq UltraScale+ ZU4EV-1E and Intel Optane Persistent Memory
Hi!
I have ready for project MPSoC module with Xilinx Zynq UltraScale+ ZU4EV-1E, 4 GByte DDR4, LP.
I want to backup whole 4GB RAM at powering off.
I want to try Intel Optane Persistent Memory as solution for fast storage to avoid long shutting down.
Willl it work? I'm really beginner.
Or knows anyone other RAM backup solution?
Thank you for each reply.
Miro
I found mentioned on the web.
Thank you.
Miro
Hi @mirkotech,
Details are provided in http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8B+MPSoC+Power+Off+Suspend
Praveen
Sadly - broken link!
Miro
Thank you.
Miro
