Xilkernel timing analysis
I am trying to do some timing analysis for xilkernal, but the results didn't make sense to me. I am using an external pin to generate interrupt and the external pin is connected to an xps_intr whose Irq then is connected to the interrupt of MicroBlaze.  I am using Spartan 3a Starter kit and clock is 62.5MHz.
1. The first test is to measure the timing from external pin raising an interrupt to ISR start, the time I got is 50us.
2, The secon test is to measure the ISR itself, the ISR code is like
  //  raise the test GPIO pin for debugging
   XGpio_DiscreteWrite (&xgpioDebugInstance, 1, 0xFF);
   acknowledge_interrupt (XPAR_XPS_INTC_0_PROCESSOR_SUBSYSTEM_INTERRUPT_PORT_0_PIN_INTR);
    // wake up the main interrupt thread
    sem_post (&ssemIntHandlerSyncSemaphore);
   //  clears the test GPIO pin for debugging
   XGpio_DiscreteWrite (&xgpioDebugInstance, 1, 0x00);
basically, it only acknowleges the interrupt and wake up an application thread.  The time I got is 202 us.
3. The third test is to measure how long it needs to wake up the application thread. The application thread is like
   while (1)
       sem_wait (&ssemIntHandlerSyncSemaphore);
       // handling the interrupt
The time I got is 306 us.
All of the times seem too long, which doesn't make sense. So anyone hs any idesa what I have done wrong?
fchpj
