akash.jn
ZC702: done pin not high on fpga!!!
I was trying to run the basic "Hello World" program using (Vivado-SDK 2017.1) on ZYNQ ZC702 dev board, but while debugging(GDB) the system, error window as seen in the attached screenshots is opening up with the below mentioned details:
Error while launching program:
Could not find ARM device on the board for connection 'Local'.
Check if the target is in:
1. Split JTAG - No operations are possible with ARM DAP.
2. Non JTAG bootmode - Bootrom may need time to enable DAP.
Please try again.
Troubleshooting hints:
1. Check whether board is connected to system properly.
1. In case of zynq board, check whether Digilent/Xilinx cable switch settings are correct.
1. If you are using Xilinx Platform Cable USB, ensure that status LED is green.
I think I messed up the configuration settings of the on-board switches. Could you please suggest some amends/resolution.
hbucher
@akash.jn The "Done" pin is showing that you have not programmed the FPGA with a bitstream.
Switches - check page 16
https://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/ug850-zc702-eval-bd.pdf
hbucher
akash.jn
Thanks for the prompt response Henry, really appreciate your help.
jhc3601212
I meet this problem, but i don't have the Done Pin problem.  I make the correct configuration with the switch to JTAG mode 00000 , but I still can't find the ARM device as the above picture shows.
