ZCU102 Rev 1.0 TRD - Possible conflict between USB host mode and display port
Hi all,
I just got the ZCU102 board and I was running the TRD as a quick test.
With the default board configuration the design starts and the video application shows its output correctly through display port.
With the jumper setup for USB host mode, however, the video output doesn't work any more. From Linux dmesg I see that the video output is not detected when I change the jumper settings.
In addition, I think UBS mouse and keyboard are still not working:
Application message:
qt.qpa.input: X-less xkbcommon not available, not performing key mapping
This is the jumper setting that I used, following the wiki page
http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2017.1
 Configure USB 2.0 jumpers for host mode
  • J110: 2-3
  • J109: 1-2
  • J112: 2-3
  • J7: 1-2
  • J113: 1-2
Thank you!
Re: ZCU102 Rev 1.0 TRD - Possible conflict between USB host mode and display port
Hello...
Do you solved this issue now ?
I got a same problem.
If somebody has information about this, please share that.
Hi there,
I was unable to fix the problem with the TRD. However, I was able to boot Ubuntu and both the display port and the USB are working.
That means the board is fine and the user guide is correct. I assume there must be some issue with the reference design, but I didn't try troubleshooting, because I only ran it to check if the board was working.
