ramyan
ZCU104 PL IRQ - GIC register overview
I would like know the register overview of the PL IRQ's (IRQ signals from PL to GICs) in the ZCU104 board.
"ug1085-zynq-ultrascale-trm.pdf" details the IRQ number for PL_PS_Group0 IRQ as 121:128 and PL_PS_Group1 IRQ as 136:142. It also details the base address of the GIC400.GICD as "0xF901_0000" and GIC400.GICC as "0xF902_0000" for a processor without security extensions. However, detailed information of the offset address of the PL IRQ status, mask, enable, disable registers are not specified.
I have referred the "Arm® Generic Interrupt Controller Architecture version 2.0" documentation to understand the detailed register overview.
1. Is the "GICC_PMR" register with offset address "0x0004" corresponds to the mask register of PL IRQ?
2. Can APU access the "GICC_PMR" register and other GIC registers?
Tags (2)
abouassi
Hi @ramyan,
You can find the needed details on UG1087. Open the link and search for GICP2 and GICP3:
Best regards,
Abdallah
abouassi
Hi @ramyan,
Best regards,
Abdallah
