akhilahmed
ZCU104: Using USB in host mode to connect to CDC class USB device
I am using the ZCU104 evaluation board to create a project where I will connect a serial USB device to the board and send/receive data serially. When I connect this USB device to a Linux machine directly, it comes up as a CDC class USB device (/dev/ttyACMx). I need to send/receive data to this device using the Ultrascale+ board in a standalone application running on the A53 processor.
Are there any reference SDK projects that demonstrate configuring the USB peripheral in host mode and communicating with the USB device?
Thanks!
suddala.s
I am facing the same problem and i have configured the kernel by following the below link
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841624/Zynq-7000+AP+SoC+USB+CDC+Device+Class+Design+Example+Techtip
after booting the board with the generated image i am unable to power up the sensor conected to board through the usb
can any one slove the issue
Sai
