rafalh11
ZDMA Flow Control
I would like to use ZDMA FCI mentioned in UG1085 Chapter 19.Is there any use case example available? I am currently using linux and I understand that current linux driver does not support flow control mode.
Best Regards,
Rafal
Tags (2)
abouassi
Hi @rafalh11,
Check the "Test Procedure" section of the ZDMA Linux Driver Wiki page.
Best regards,
Abdallah
rafalh11
Test Procedure describes usage of DMA without FCI. I am only interested in FCI interface of the DMA at the moment.
