ZYNQ AXI bus
We are going to design a system based on zynq-7000, in which it includes multiple master axi device and slave axi devices. As this is my first time for using AXI, I wonder can I set multiple transfer between different couple of master-slave via the interconnection? It seems build multiple channel simultaneously. Could somebody give me  one point or reference doc? Thank you in advance.
Wei
Yeah, check out the discussion on N-to-M Interconnect (Crossbar Mode) in PG059
www.xilinx.com
www.xilinx.com
