ZYNQ Program Flash gets stuck at 0%
I am using a ZYNQ custom PCB board with the 14.7 of XPS and SDK. I have a Micron 1Gb NAND in my system and I want to access it through Xilinx Tools -> Program Flash. I have also set my board to JTAG boot mode.
After exporting my design to SDK, I create a FSBL project to use its .elf and a random .bin file. When I click the Program Flash button however, I get the following screen and the programming gets stuck at 0%:
Has anyone faced this problem before?
Berk
Okay here I found that the Xilinx tool for the type of NAND we are using is to be announced (MT29F1G):
http://www.xilinx.com/support/answers/50991.html
Can this be the reason? Is someone else using a NAND from micron which is a MT29F1G?
Berk
TBA usually means "we know of a reason why it doesn't work and we are working on it". I wouldn't hold my breath, I am sorry to say.
