Anonymous
Not applicable
ZYNQ writing/reading image to/from SD card example - any example
Is there any working example to read/write image (bmp or jpeg) from/to SD card wich can be implemented on ZYNQ development board ?
chaoz
hi,
Are you doing that with or without linux? what filesystem on you SD cards?
You may want to refer to xilffs libarary if you are using baremetal. Lib and examples can be found in SDK.
https://github.com/Xilinx/embeddedsw/tree/master/lib/sw_services/xilffs
-chaoz
Anonymous
Not applicable
I am looking for standalone OS for ZYNQ which can read and write to SD card. I am not sure about file system of SD card. What is the filesystem requirement for ZYNQ development boards ? I am running Vivado in Windows.
dpaul24
@Anonymous,
Google search : "image read/write Sd card zynq"
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
chaoz
hi @Anonymous
As you are using standalone, you can try that xilffs library, can be included in BSP settings as below. It's FAT filesystem.
