ZedBoard SPI interrupt code
Can anyone please share interrupt base SPI code for zedboard.
Thanks in advance.
Re: ZedBoard SPI interrupt code
HI @mohanv,
Interrupt is not a MIO pin, it is a signal from SPI controller to Zynq.  So there is no way to connect this signal to MIO pins.
There is already a XScuGic interrupter controller is present in Zynq and you need to connect your SPI to this controller to enable the SPI interrupts (this can be done in SDK if you are using SDK).
Best Regards,
Srikanth
Hi @mohanv,
If you have the hardware design built in Vivado and exported HDF to SDK workspace then will be able to get example templates for SPI interrupt.
Praveen
Hi Praveen
In my viviado project by enabling the SPI i got 4 MIO's(MOSI,MISO,SCLK,SS) but for my project interrupt pin also required.
How to enable the interrupt pin(MIO) in vivado in addition to 4MIO's.
Praveen.
Hi @mohanv,
Could you check in PS configuration -> PS-PL interface -> General -> Interrupts -> PS-PL -> SPI?
Praveen
HI @mohanv,
Best Regards,
Srikanth
Thank you Srikanth
I am able to transmit the data over SPI in Zedboard(Master), but in my project a have to read acknowledgement from slave.
In this code i'm unable to receive  acknowledgement.
static uint32_t waitTransmit(XSpiPs *InstancePtr)
uint32_t StatusReg;
uint32_t CheckTransfer = 0U;
while (CheckTransfer == 0U)
StatusReg = XSpiPs_ReadReg(InstancePtr->Config.BaseAddress, XSPIPS_SR_OFFSET);
if ( (StatusReg & XSPIPS_IXR_MODF_MASK) != 0U) {
* Clear the mode fail bit
XSpiPs_WriteReg(InstancePtr->Config.BaseAddress,
XSPIPS_SR_OFFSET,
XSPIPS_IXR_MODF_MASK);
return XST_SEND_ERROR;
CheckTransfer = (StatusReg & XSPIPS_IXR_TXOW_MASK);
return XST_SUCCESS;
static void manualStart(XSpiPs *InstancePtr)
uint32_t regValue;
regValue = XSpiPs_ReadReg( InstancePtr->Config.BaseAddress, XSPIPS_CR_OFFSET);
regValue |= XSPIPS_CR_MANSTRT_MASK;
XSpiPs_WriteReg(InstancePtr->Config.BaseAddress, XSPIPS_CR_OFFSET, regValue);
return;
void spi_tx(char *data,int length)
for(int i=0;i<length;i++)
XSpiPs_SetSlaveSelect(&xspi,0);
XSpiPs_Enable(&xspi);
XSpiPs_Out32(xspi.Config.BaseAddress + (u32)XSPIPS_TXD_OFFSET, (u32)(data[i+1]));
XSpiPs_Out32(xspi.Config.BaseAddress + (u32)XSPIPS_TXD_OFFSET, (u32)(data[i]));
manualStart(&xspi);
waitTransmit(&xspi);
readData[i] = XSpiPs_In32(xspi.Config.BaseAddress + (u32)XSPIPS_RXD_OFFSET);
readData[i+1] = XSpiPs_In32(xspi.Config.BaseAddress + (u32)XSPIPS_RXD_OFFSET);
XSpiPs_SetSlaveSelect(&xspi,0xF);
XSpiPs_Disable(&xspi);
In another way
XSpiPs_PolledTransfer(&xspi, data,readData, length);
By using xilinx API
By using both the functions i'm receiving 0x0000000 in some cases 0xFFFFFFFF.
Can any one suggest where i am facing the problem.
