Zybo And Sdk 2014.2 Debug Problem
I have problem with debugging in Xilinx's SDK 2014.2 with my ZYBO board. Jumper on board is set to JTAG, Programming of FPGA with created ZYNQ design is done correctly but when I try to debug, program doesn't halt in main() but already runs and instead of winddow with code, theres is empty windows with "No source avaible" and disassembley window  is also empty.
In attached files is my debug configurations for GDB.
Could anybody help me?
Can you check if the highlighted GBD option is enabled?
Achutha
Yes, that options is enabled... That was first place where I looked at.
How does your 'Application' tab look like?
It should be in the debug folder as below and not a release version:
It's look like this, I guess it's ok...
