rcjhy8
Zybo I2C Example Failed
Hello all,
I am using a Zybo 7000 developement board and am trying to create a project such that I can communicate with a sensor over I2C.
I have programmed my fpga in Vivado, and added I2C scl and sda to pins W19 and W20 respectively. In sdk, I can complete the hello world and repeated start example with no issues.
I read from another forum that using the "master polled" example was a good start for establishing communication as it was just simple read/write functions.
Inside this master polled, I have changed the slave address from 0x55 to 0x62, as per my actual sensor address. Also I added additional 1k pull-up resistors in like with the SDA & SCL lines. I then run as debugger and the example fails.
Am I missing a declaration somewhere? Thanks,
Russell
venui
Can you please share your source code completely to understand what you are doing and slave device data sheet.
Venu
rcjhy8
DAC datasheet - https://www.sparkfun.com/datasheets/BreakoutBoards/MCP4725.pdf
Source Code is just master polled example with line that I changed to DAC hex address.
* Copyright (C) 2010 - 2019 Xilinx, Inc. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* XILINX BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
* WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
* OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
* Except as contained in this notice, the name of the Xilinx shall not be used
* in advertising or otherwise to promote the sale, use or other dealings in
* this Software without prior written authorization from Xilinx.
* @file xiicps_polled_master_example.c
* A design example of using the device in polled mode as master.
* The example uses buffer size 132. Please set the send buffer of the
* Aardvark device to be continuous 64 bytes from 0x00 to 0x3F.
* <pre> MODIFICATION HISTORY:
* Ver Who Date Changes
* 1.00a jz 01/30/10 First release
* </pre>
/***************************** Include Files **********************************/
#include "xparameters.h"
#include "xiicps.h"
#include "xil_printf.h"
/************************** Constant Definitions ******************************/
* The following constants map to the XPAR parameters created in the
* xparameters.h file. They are defined here such that a user can easily
* change all the needed parameters in one place.
#define IIC_DEVICE_ID XPAR_XIICPS_0_DEVICE_ID
* The slave address to send to and receive from.
#define IIC_SLAVE_ADDR 0x62 //This is the address of the Arduino ADC
#define IIC_SCLK_RATE 100000
* The following constant controls the length of the buffers to be sent
* and received with the IIC.
#define TEST_BUFFER_SIZE 132
/**************************** Type Definitions ********************************/
/************************** Function Prototypes *******************************/
int IicPsMasterPolledExample(u16 DeviceId);
/************************** Variable Definitions ******************************/
XIicPs Iic; /**< Instance of the IIC Device */
* The following buffers are used in this example to send and receive data
* with the IIC.
u8 SendBuffer[TEST_BUFFER_SIZE]; /**< Buffer for Transmitting Data */
u8 RecvBuffer[TEST_BUFFER_SIZE]; /**< Buffer for Receiving Data */
* Main function to call the polled master example.
* @param None.
* @return XST_SUCCESS if successful, XST_FAILURE if unsuccessful.
* @note None.
int main(void)
int Status;
xil_printf("IIC Master Polled Example Test \r\n");
* Run the Iic polled example in master mode, specify the Device
* ID that is specified in xparameters.h.
Status = IicPsMasterPolledExample(IIC_DEVICE_ID);
if (Status != XST_SUCCESS) {
xil_printf("IIC Master Polled Example Test Failed \r\n");
return XST_FAILURE;
xil_printf("Successfully ran IIC Master Polled Example Test\r\n");
return XST_SUCCESS;
* This function sends data and expects to receive data from slave as modular
* of 64.
* This function uses interrupt-driven mode of the device.
* @param DeviceId is the Device ID of the IicPs Device and is the
* XPAR_<IICPS_instance>_DEVICE_ID value from xparameters.h
* @return XST_SUCCESS if successful, otherwise XST_FAILURE.
* @note None.
int Status;
XIicPs_Config *Config;
int Index;
* Initialize the IIC driver so that it's ready to use
* Look up the configuration in the config table,
* then initialize it.
Config = XIicPs_LookupConfig(DeviceId);
if (NULL == Config) {
return XST_FAILURE;
Status = XIicPs_CfgInitialize(&Iic, Config, Config->BaseAddress);
return XST_FAILURE;
* Perform a self-test to ensure that the hardware was built correctly.
Status = XIicPs_SelfTest(&Iic);
return XST_FAILURE;
* Set the IIC serial clock rate.
XIicPs_SetSClk(&Iic, IIC_SCLK_RATE);
* Initialize the send buffer bytes with a pattern to send and the
* the receive buffer bytes to zero to allow the receive data to be
* verified.
for (Index = 0; Index < TEST_BUFFER_SIZE; Index++) {
SendBuffer[Index] = (Index % TEST_BUFFER_SIZE);
RecvBuffer[Index] = 0;
* Send the buffer using the IIC and ignore the number of bytes sent
* as the return value since we are using it in interrupt mode.
Status = XIicPs_MasterSendPolled(&Iic, SendBuffer,
TEST_BUFFER_SIZE, IIC_SLAVE_ADDR);
return XST_FAILURE;
* Wait until bus is idle to start another transfer.
while (XIicPs_BusIsBusy(&Iic)) {
/* NOP */
Status = XIicPs_MasterRecvPolled(&Iic, RecvBuffer,
return XST_FAILURE;
* Verify received data is correct.
for(Index = 0; Index < TEST_BUFFER_SIZE; Index ++) {
/* Aardvark as slave can only set 64 bytes for output */
if (RecvBuffer[Index] != Index % 64) {
return XST_FAILURE;
return XST_SUCCESS;
venui
Please arrange your code w.r.to data sheet
1. The buffer size needs to be changed.
2.The following code not related to your sensor please remove
return XST_FAILURE;
3. Write the actual values into the registers adn read it back and validate.
Venu
