Zynq-7000 MIO 7 & 8
Hello there,
I wish to get the following clarified:
Are all MIOs not used by enabled PS7 peripheral available as freely reconfigurable user GPIOs?
Because from the customization panel,  see picture below, it seems 7 and 8 can be set to output only.
Re: Zynq-7000 MIO 7 & 8
MIO7 and MIO8 can only be used as outputs (ug585v1.12.2-2.5.4-page 52)
Yes, you are right
Hi @guidopc ,
Refer UG585 check topic 2.5.4 MIO-at-a-Glance Table and also check chapter-6 Boot and configuration.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
