Zynq FSBL - QSPI init hangs
I am using FSBL application provided by SDK 2017.2.
FSBL application goes into InitQspi() function but never returns. It actually hangs inside XQspiPs_CfgInitialize(). Going deeper I figured out that the execution of the application simply stops in XQspiPs_Abort function during this line:
XQspiPs_WriteReg(InstancePtr->Config.BaseAddress,
		XQSPIPS_RXWR_OFFSET, XQSPIPS_RXWR_RESET_VALUE);
I am not able to even stop the application after this point and see the call stack, SDK does not respond. Any ideas what could be the issue or how to debug it?
Nenad
I have found a workaround for this problem, but I am not exactly sure what the cause of the problem is.
What I noticed first is that InitQspi() doesn't fall if called before ps7_init() function in fsbl application. However, it did hang at some later point in the program. I decided to copy ps7_init.c from our previous project (done in Vivado/SDK 2016.2) for which I didn't have this problem at all. After I copied it in my current hw platform wrapper, the fsbl application completed successfully and I have booted my application from Flash.
Obviously, there is some problem in ps7_init.c file generated by the Vivado/SDK. I am not sure what's the exact problem and I am not planning to debug it.
Xilinx, can you please check what's the real cause of this?
Thank you,
Nenad
Is this a custom board? Have you the QSPI enabled in the PS config in vivado?
yes, it is a custom board. In the past (last year, with previous project) I succeeded to run this FSBL application on this board (I don't see any differences in FPGA designs between two projects).
Yes, I have enabled QSPI, otherwise the QSPI init wouldn't be even called in the first place.
Nenad
Interestingly enough, when I run application from xqspips_flash_lqspi_example.c, I don't have the problem with init function. Moreover, the test completes successfully.
What could this mean?
P.S. I use the exact same bsp for both fsbl and this test application.
Thank you,
Nenad
I had a similar problem, it turned out to be a wrong QSPI clock setting in the ps7 init.
